 Project Car Thread - Index
PostSubject: Project Car Thread - Index   Wed Dec 02, 2009 3:09 am
To make things easier for Members and Myself, I have been creating an
Index for the Project Car - HBF 369 - Thread. good idea
Work in Progress (WIP).
As I finnish a page I will update the Index highfive
PostSubject: Re: Project Car Thread - Index   Mon Jan 11, 2010 8:37 pm
Please be aware the first 4 pages of the Project Car - HBF 369 - thread are very picture heavy so take a while load depending on your network connection speed.
Arrow Page 1
Car Collection, Wash & Photos Arrow Headlamp\Fuse Issue Arrow Clean up \ Check Over \ Grease Nipples Arrow Tyre Codes & Prices Arrow Engine Pictures Arrow Changing of Air Filter & Seal Arrow Bonnet Tension Spring Issues Arrow Lube Service & Coolant Change Arrow Changing Rear Light Seals & Gaskets Arrow Front Number Plate Tips Arrow Gearbox Oil Change, New Rubber Grommets Arrow Passenger Side Interior Strip out Arrow Seat Runners Lubrication Arrow Front ARB Bracket & Rubber Replacement Arrow Steering Bushes Changed Arrow Foot Pedal Rubbers changed
Arrow Page 2
Changing Radiator Duct \ Plugs \ Moroso Leads Arrow Oil Leak Issue Arrow Heater Box Dash Seal Renewal Arrow New Tyres Arrow Nut & Bolt Advice Arrow NS Bumper Removal \ Refit New Seal Arrow Bleeding Rear Brakes Arrow Damper Removal Arrow Car Falling off Stands Embarassed Arrow New Goodridge Braided Hoses Fitted Arrow Rear ARB Rubbers & Droplink Replacent Arrow Advice on Dampers Arrow Front Brake Bleed & New Goodridge Braided Hoses Arrow Front ARB Rubbers & Droplink Replacent Arrow Cleaning NS Seat & Replacing Carpet with Hardura
Arrow Page 3
Intermittent Misfire Arrow Fuel Tank Assembly Removal Arrow New Petrol Filler Cap Arrow Air Filter Seal Adjustment Arrow Engine Detailing Begins Arrow Fitting a Smaller Period S \ Wheel Arrow Horn Issues Arrow Axle Ratio Question Arrow 123Ignition Info Arrow Dynamo = +ve Earth Arrow Earthing the Engine Arrow Front ARB Bushes Arrow New Bonnet Tension Springs Fitted Arrow Eratic Misfire Diagnostics Arrow Eratic Misfire Resolved Arrow More Horn Diagnostics Arrow Sourcing Horn Kit
Arrow Page 4
Removal of USC Arrow Horn Advice Arrow USC \ Horn Advice Arrow Pre USC Install Arrow Horn Relay Arrow LSC UJ Removal Arrow USC UJ Rebaild & USC Install Arrow Tidy up the Engine Frame Arrow New Rear Number Plate Arrow 2010 Fetteling Commences Arrow Removal of Rad & Front ARB
Arrow Page 5
F. ARB Removal Arrow Strip Down Arrow Refurbing Parts Arrow Radiator Arrow Update Arrow Changing Coolant Hoses Arrow RHT in Hammerite Silver Arrow Waterpump Hose Arrow Radiator Duct Shield Arrow VHT on Pulley Wheels Arrow Reservac Hoses
Arrow Page 6
Re-fitting LSC & Steering Rack Arrow Installing Coolcat Motor & Fan Arrow Connecting Rad to Water Pump Arrow Removal of Heater & Exhaust Manifolds Arrow Engine Detailing Begins Arrow Sump Removal (I tried) Arrow Refit Breather Cover Arrow Cam Polishing Arrow Dropping the Oil, Filter and Filter head Removal Arrow Retorquing the head Arrow RHT Re-fit Arrow Re-fit Manifolds to Downpipes Arrow WPRP fitted Arrow Breather Hose fitted
Arrow Page 7
Re-Tourquing Camshamft Covers Arrow Swapping Out Dampers Arrow Refitting Bonnet Tension Springs Arrow Refitting Heater Box & Hoses Arrow Ready for the Road Nearly Arrow Breather Pipe Arrow Final Tweeks Arrow The Outcome (after the Testdive) Arrow Cam Cover Fix Guide Arrow Overheating issues
Arrow Page 8
Arrow New HT Leads Arrow Cam Cover Weep Arrow Plenum Refurb Arrow Cam Cover Welding Arrow Filter Fan Relay Arrow Brake Hoses Swap Out Arrow Rewiring the Loom @ Prescott Arrow Wheel Alignment Toe In Arrow Oil Leak
Arrow Page 9
Arrow MOT 12\07\2010 Arrow USC Stripdown Arrow Self Cancelling Indicators Arrow Camshaft Oil Filler Cap Trick Arrow Air Balance Pipe & Slave Shaft Assembly Arrow Air Intake \ Carb Insulator Gaskets Arrow Removing the Triple SU's Arrow Fully Removed SU's Arrow Refitting the Triple SU's Arrow Completing the Refit
Arrow Page 10
WiP car spanner pullhair RTFM Coffee swear lol! scratch And last but not least this car puts a Very Happy on your face Exclamation Streetracing
» MUSCA project
» The Italian Thread
» DMIA project above board; CIAC to penalize contractor
» Project - making shirts
» DOTC still reviewing Northrail project
The Jaguar Mk10 & 420G Owners Symposium :: More Cars From Sir William Lyons Production Line :: Edward - 1962 E-Type S1 3.8 FHC - 860871-
