 LSD Question
PostSubject: LSD Question   Sun Jan 30, 2011 11:25 am
Am I right that the MK10 had a LSD , if so why was this deleted for the 420G ?
Thanks Alan S.S.O.C
jag420g
Resident Mk10\420G Guru
jag420g
PostSubject: Re: LSD Question   Sun Jan 30, 2011 12:02 pm
Alan,
Why do you say this was deleted??? To my knowledge:
The rear axle was a SALISBURY HYPOID LIMITED SLIP across the entire range, from the mark 10 3.8 litre to the 420G.
Charles smoker
PostSubject: Re: LSD Question   Sun Jan 30, 2011 12:20 pm
jag420g wrote:
Alan,
The rear axle was a SALISBURY HYPOID LIMITED SLIP across the entire range, from the mark 10 3.8 litre to the final 420G.
Charles smoker
Not to my knowlege Charles , only fitted to MK10 and then returned to a normal diff for the 420G . My car has the original diff and that's not a LSD .
Asked this question on the JWM Forum , reply came it was not an optional extra , but what I would like to know is why ?
Alan S.S.O.C
jag420g
jag420g
PostSubject: Re: LSD Question   Sun Jan 30, 2011 12:28 pm
Alan, yes I see where you are coming from: let me elaborate, What I wrote earlier holds true, but from chassis no. G1D 54476 RHD The limited slip "Powr lock Differential was deleted from the final drive unit of 420G cars in favour of a conventional differential. However I cannot shed any light as to the reason at this stage.
Charles smoker
PostSubject: Re: LSD Question   Sun Jan 30, 2011 12:54 pm
Charles ,
it's a strange one , why fit to only a few then revert to conventional ? if a change was to be made surly the time would have been right at the introduction of the 420G .
I shall investigate further .
Alan S.S.O.C
LSD Question
» SEBI QUESTION AND ANSWERS
» The Question for Hizb 11: ...and let not the ___________ and hatred of others make you avoid justice
» The Question for Hizb 8: Allah will not leave the believers in the state in which you are now, until He ________ the wicked from the good.
» What can Satan See?
» Question on Uniform Guidelines For Blacklisting Of Manufacturers, Suppliers, Distributors, etc.
