 Duane's Classic Jaguar Quiz
Go to page : Previous  1 ... 10 ... 15, 16, 17
JustV12
JustV12
PostSubject: Re: Duane's Classic Jaguar Quiz   Wed Apr 06, 2016 5:11 am
OK, if there are crickets out there have them pipe down.
I first have to apologize as this question is not at all up to the standards of the old ones. But lets call it a "soft start" shall we?
Typically I spend quite a lot of time researching these things and lately I have jut not had that time. Hopefully things settle down a bit this coming weeks.
I will have to refresh my memory as to the way I did things and keep the standards up.
SO, here we go:
All of us with early MK 10's will be able to recognize a switch to the side of the steering wheel.
That is a hold switch for the transmission.
Can you tell me what year they were discontinued and also, what year did the shift pattern on the automatic transmission change?
This should b a very easy one.
Cheerio
Duane
62 MK 10 Silver Grey
89 XJ-S Convertible
89 XJ-12 VDP BRG. In Canada Vanden Plas is NOT a Daimler Double Six, its the highest model Jag.
1949 Daimler Barker db18 Special Sports 2.5 Litre Drop Head Coupe (See my Icon pic)
1985 XJ-6 Daily driver (Yes I am very serious. Rust? What rust?)
1989 XJ-S Convertible grey parts car
Plus ummm a 2001 VW Passat estate, belongs to my wife...honest.
And I would never admit to owning a 2002 Pontiac Montana...EVER.
http://www.contigoliving.com
PostSubject: Re: Duane's Classic Jaguar Quiz   Wed Apr 06, 2016 5:28 am
I have never owned a Mk10 so a stab in tbe dark.
Did the switch get discontinued in '64 when the car changed from
the 3.8 to the 4.2 Question
Part 2 : no idea, I didn't know it had changed
1970 4.2 420G -13th from last RHD -Ronnie (New Custodian Required)
awg
PostSubject: Re: Duane's Classic Jaguar Quiz   Wed Apr 06, 2016 2:55 pm
as far as I am aware, the DG250, which was fitted to 3.8, has a different auto shifter gate position to the BW8 equipped 4.2MKX. So '65, or '66, depends how you interpret when an "car year" ends & begins
PostSubject: Re: Duane's Classic Jaguar Quiz   Sat Apr 23, 2016 7:32 am
How you doing for a new question Duane Question
Maybe a new question once a week if possible to keep
the interest up... What do you think Duane
JustV12
JustV12
PostSubject: Re: Duane's Classic Jaguar Quiz   Wed Apr 27, 2016 1:13 pm
Hi All, clearly I am rather late for the answer but here it is:
Like a lot of things Jaguar the answer isn't so simple.
The Transmission on the early cars had a pattern of P-N-D-L-R. Meaning that you could not manually shift the car into second gear hence the need for the switch which held the car in second gear for the sake of passing, accelerating onto a motorway or climbing hills. When the transmissions were switched to a more conventional P-R-N-D-D2-L the switch became redundant.
You note that on the latest 420G there should be no switch.
When the transmissions were gradually replaced with conventional units the switches disappeared.
Manual transmission cars never had such a switch it was only the automatic cars.
The shift pattern indeed began to change in 1964 when the 42 engine replaced the 3.8, so cheers to CLive for that "stab".
Going forward I emphasize that my enthusiasm for this quiz thread has never waned, however my spare time has not been kind to me. I do wish to continue and I do wih to be more regular. In the mean time if you can keep your eyes opene, I will have another question very soon.
Cheers
Duane
89 XJ-S Convertible
JustV12
JustV12
PostSubject: Re: Duane's Classic Jaguar Quiz   Wed Apr 27, 2016 1:16 pm
OOH, Mr "JustV12" thinks that to be a lovely header pic up there.
tongue
DG
89 XJ-S Convertible
PostSubject: Re: Duane's Classic Jaguar Quiz   Fri Apr 14, 2017 1:41 am
Thanks DG I know you are active on our Facebook group, any chance of a question for here for the Easter Holiday
JustV12
JustV12
PostSubject: Re: Duane's Classic Jaguar Quiz   Fri Apr 14, 2017 1:53 am
Yes, I am thinking of this page actually. I was here recently and noted not much activity.
But, FB might be the answer. Not only to revive the Quiz but also maybe drive traffic here??
Let's give it a shot. I'll think of something to post today if I can.
89 XJ-S Convertible
PostSubject: Re: Duane's Classic Jaguar Quiz   Fri Apr 14, 2017 2:00 am
That sounds good Duane...
If its Zenith related you can put the link on the facebook group and hopefully direct some of the traffic this way as well..
PS. We now have a Passat Estate in our household..... a good work horse I must say great
Page 17 of 17Go to page : Previous  1 ... 10 ... 15, 16, 17
» Manners, Etiquette & Politeness Quiz
» QUIZ!!! More Little Cherubs, Imps and Assorted Devils to Identify!
» bM 2000 & ideal Classic ff370 on off on off issue
» scalding hot water
» Jumu'ah Nasiha-Sabr or Shukr – The Worry Stops Here
