 Heated Rear Windows
PostSubject: Heated Rear Windows   Tue Aug 24, 2010 3:18 am
The car I veiwed yesterday had a heated rear window, I was told two wires come out the glass
but these were damaged when the rubber seal was changed and the window didnt work Sad
Any knowledge \ tips advice on this appreciated scratch study
1970 4.2 420G -13th from last RHD -Ronnie (New Custodian Required)
jag420g
Resident Mk10\420G Guru
jag420g
PostSubject: Re: Heated Rear Windows   Sat Aug 28, 2010 9:49 pm
Clive,
It will be necessary for you to ascertain where the break in the wire has occurred.
If you are able to see the wires under the rear parcel tray bulkhead by removing the trim locally and looking for a black and black and white wires with snap connectors you should be able to get some idea of what is going on. If the break is too close to the rear glass you may have to replace the backlight if you want the demister to work, otherwise you may be able to splice what is there.
You realize that those wires from the glass actually have to pass through the rear screen rubber seal then through the rear bulkhead to their mating snap connectors--- Have fun in the boot won't you!
Charles
PostSubject: Re: Heated Rear Windows   Sat Aug 28, 2010 9:58 pm
Charles
The rear window rubber has been changed recently, I think someone wasnt to carefull when putting it back in Evil or Very Mad
Heated Rear Windows
» Boarded up windows given a telephone number to ring in a dream it is real limousine hire
» Whistling pump!
» Direct imaging of exomoons
» hitting tennis ball breaking windows
» OT: "Off-Topic Island"
